- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Wifi Extender or Access Point
- Mark as New
- Bookmark
- Subscribe
- Permalink
I want to extend my network. I'm wondering if I need a range extender or wireless access point. I plan to plug either device into the main router via ethernet cable. I'd like as little speed degredation as possible. I am using a nighthawk router.
Thanks for the help
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Wifi Extender or Access Point
If you can run a cable AP is the choice.
- Mark as New
- Bookmark
- Subscribe
- Permalink
One more question. Am I better using the newer nighthawk as the main router and the wndr4000 as an AP or would it be better the other way around? The main router will be in a utility room while the AP will handle most of the wireless connections
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'd always put better router at the front. So far I have been covering my whole house with just one router but when if I had to deploy AP
that's what I'll do.
- Mark as New
- Bookmark
- Subscribe
- Permalink
What do you by at the front. My tought was I'd use the WNDR4000 as the main router with the wireless turned off placed in the utility room and then the nighthawk 7000 as the AP to handle the wireless part placed centrally in the house
- Mark as New
- Bookmark
- Subscribe
- Permalink
Sorry, I meant front end which is after modem. So modem >> your better router >> another router as an AP. If you put the lesser router
at the front it can choke the traffic flow. Any how to customize your situstion you can try both ways. Good luck.
