- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Wifi Modem changed/upgraded. Can not connect to Netgear AC750 wifi Range Extender
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Telstra gave me a smart wifi modem with a different WIFI name. After the change over, I am unable to get the Netgear Extenstion to reconnect to the new Wifi. Any device still displays the previous Wifi name-ext.
I referred to and used the instructions to make a change. Tried to connect to Netgear_ext WIFI on either of my tablet or mobile, BUT under the WIFIs to be selected, the "Netgear_ext" did not appear for selection. I also attempted this processs the using the Nighthawk APP.
I have also pushed the RESET button on the Netgear Device. I no longer have extended WIFI use. Can someone please assist me.
thank you
Colette
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: Wifi Modem changed/upgraded. Can not connect to Netgear AC750 wifi Range Extender
What extender do you have? AC750 is a speed.
When you reset, did you push and hold reset for 7-15 seconds while it was powered on? many just click the reset button.
What router are you connecting it to (model)?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
What extender do you have? EX3110 NETGEAR
I will try to do this again.
What router are you connecting it to (model)? TELSTRA SMART MODEM,
Technical stuff
- Inbuilt, pre-activated SIM to connect to 4G when required
- DSL port for your ADSL2+ or VDSL2 home broadband connection
- 4x4 802.11ac – the fastest ratified Wi-Fi standard
- one 3.0 USB port
- one gigabit Ethernet WAN port
- four gigabit Ethernet ports
- WPS push button
- Dual band capability (2.4GHz and 5GHz)
- 256MB RAM
it was previously was a Telstra Wifi modem that relied on the NBN working.
