- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Wifi extender Client light red or not on
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am able to connect to the internet using an ethernet cable from my pc to the extender but the client light is either off or red. I have treid a different cable but that made no difference.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Wifi extender Client light red or not on
@Harri_P wrote:I am able to connect to the internet using an ethernet cable from my pc to the extender but the client light is either off or red. I have treid a different cable but that made no difference.
I'm a bit confused. You've hooked your computer to the extender and its working? but you're wondering why the led isn't lit up?
- Mark as New
- Bookmark
- Subscribe
- Permalink
i think my connection is fluctuating as the light keeps changing. my connection to the router is always solid green. im unsure why the light is indicating poor client connection
- Mark as New
- Bookmark
- Subscribe
- Permalink
Have you tried a differnet client connected? See if a different laptop has the same issue. Maybe the port on your pc is bad. You said you've tried different cables.
Does it do the same over wireless?
- Mark as New
- Bookmark
- Subscribe
- Permalink
i dont have anything to test the port on the pc. using it wirlessly just give a poor speed overall. its usually alright but im confused as to why its telling me the connection if poor or none exsistant
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
