- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Wifi extender EX2700 - works for email and browsing but signal not strong enough for Zoom/Teams etc.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Wifi extender EX2700 - works for email and browsing but signal not strong enough for Zoom/Teams
How far away is it?
A little fyi about how extender work.
The standard extender has to send and recieve using the same chip. and they can't do both at once. So their speed is automatically 50% of whatever speed they're getting in that spot. so if they're already at a distance from the router and only picking up a 10mbps speed, they're output is only going to be 5mbps. So if you're using a base model N300 extender at a distance from the router you've already got a poor signal being rebroadcast at 50% speed by a basic extender.
The triband extenders and mesh networks mitigate this by dedicating 1 of the 5ghz bands just for router---extender communication.
without knowing distance or obstacles in the way all I can give is general ideas.
1. run a underground ethernet wire to where you need it and connect an extender/router in AP (access point) mode.
2. run powerline to where you are. Not all homes/wiring setups work well with powerline
3. use a moca adapter (ethernet over coax) if you've got coax ran out there.
4. Try one of the triband extenders. That way if its a distance issue where you're only getting 10mbps at that location, you keep that full speed and don't lose half of it.
5. upgrade to a mesh system where you can place multiple satellites as needed. Like netgear Orbi. But i'd go for the tri-band system and not the dual band.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks Plemans
There is an external brick wall between the extender and the wooden office in my garden. It's a relatively cheap extender. Maybe you get what you pay for! I have followed your sugestion and ordered a tri-band extender. Here's hoping! Thanks again
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hope it helps. Brick, concrete, and metal are pretty much the bane of wifi as they're excellent at blocking signal. If i'd have known that was there, i'd have pushed for you to run a cable, powerline, moca adapter. Its just challenging to get wifi through t hose.
- Mark as New
- Bookmark
- Subscribe
- Permalink
No worries - thanks for bothering. I have tried the powerline. It works for an internet phone but not for the computer for some reason. Running a cable would be pretty tricky - it's an awkward route. The tri-band extender seems worth a try. The reviews suggest it has worked in similar situations where a cheaper extender has failed. Thanks again.
