- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Wifi extender & password
- Mark as New
- Bookmark
- Subscribe
- Permalink
The model number of the wifi extender is: WN3000RP
Any help gratefully received!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Wifi extender & password
I'm having the same problem connecting to my WN2000RPTv2 extender. The extender is connected to the primary router just fine and the signal is strong. My iPhone recognizes the extender's wifi connection, but it won't accept the password. I'm using the same password I use for the primary router. Help would be appreciated.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi SomersetSarah,
Please try resetting the WN3000RP to factory defaults:
Press and hold the Factory Settings button on the side panel for 7 seconds. The Extender resets, and returns to its factory settings
Place the WN3000RP in the same room as your router.
Then try setting up the WN3000RP again:
See page 8 of 32:
http://www.downloads.netgear.com/files/GDC/WN3000RP/WN3000RP_UM_1Feb13.pdf
Which router is connected to the Extender?
Please update the router to latest firmware.
Hi Diehard50248,
Please try the same procedure but for the WN2000RPTv2
http://www.downloads.netgear.com/files/WN2000RPT_UM_05MAR2012.pdf
After setting up the WN2000RPTv2, "Forget" the old WiFi networks on your Apple devices and connect to the new ones
