× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Wifi extender problem
tamersherif0
Follower
I have a Nighthawk AC1900 range extender and i ran into a problem that im extending a wifi that's available with same ssid and password multiple times, but i want to always select a specific access point and stick to it instead of keep switching between different APs with the same name. Is it possible to select the AP to extend using Mac Address?
Message 1 of 2
DarrenM
Sr. NETGEAR Moderator
Re: Wifi extender problem
The only way I can think to do this is maybe you add it to the wifi block list of the main router but that could make the AP block it as well.
DarrenM
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 994 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
