× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Wifi mesh extender
Khabusta
Follower
Wifi mesh extender
I have gone through the process on the Nighthawk app to set up my wi fi extender but it wont connect to wifi. I have triple checked that my phone is connected to the correct network.
Model: C6300|AC1750 Cable Modem Router Docsis 3.0
Message 1 of 2
Guru
Re: Wifi mesh extender
What extender are you using?
The router you connected it to is the C6300?
You put 'it won't connect to wifi". What won't connect, the extender? The device trying to connect to the extender?
a little more details/description helps us since we aren't there to see whats going on?
Message 2 of 2
Discussion stats
  • 1 reply
  • 217 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
