× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Wifi name will using EX6250
skrisher
Follower
I have followed the instructions and set up the extender. What wifi name should I be looking for/connecting to? My original wifi connection or the NETGEAR_EXT connection? The NETGEAR_EXT connection disappeared after setup so I suspect the mesh combined the EXT connection with my original but don’t know enough to confirm. Any help is much appreciated!
Model: EX6250|AC1750-WIFI MESH EXTENDER
Message 1 of 2
Accepted Solutions
Guru
Re: Wifi name will using EX6250
Yes, when you set it up in mesh mode, it uses the same ssid as the router.
You shouldn't have to select anything. Your device's (tablet, phone) own roaming protocol should switch it between router---extender as needed.
If it doesn't function well, you can always disable it and set your own ssid for the extender.
https://www.netgear.com/support/product/EX6250
Message 2 of 2
All Replies
Guru
Message 2 of 2
Discussion stats
  • 1 reply
  • 494 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
