sskkroto24's avatar
sskkroto24
Follower
Sep 25, 2019
Wifi range extender flashing green light
I installed the extender and set up my network.  After that process, I was asked if I wanted to update the firmware.  I had to step away for a few minutes after that started.  Afterwards, I saw only a green blinking light -no router or device light.  I have turned off/on and get a solid amber boot light, then blinking green light.  I have tried resetting to factory settings and nothing happens, just blinking green light continues.  Pushing the WPS button, nothiing happens -no blinking WPS light.  I have tried plugging in by ethernet with no results -no Device light.
1 Reply
