× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Will WN3000RP work with Actiontec router?
c_reality
Novice
I'm looking to purchase the NETGEAR WN3000RP to extend the range of my wireless network. The simplicity of the device is enticing. However, I have Verizon FiOS and as such also have an Actiontec MI424WR router.
The WN3000RP info says that the device is setup easily with WPS. Great, except the MI424WR doesn't have the ability to do WPS.
Here's the question which I can't find the answer to in the WN3000RP literature: is there any other way (other than a hard wire) to wirelessly connect/setup the WN3000RP and the MI424WR?
Thanks!
Message 1 of 2
jmizoguchi
Virtuoso
Re: Will WN3000RP work with Actiontec router?
it can uses standard WPA2 ,WPA encryption to join the existing network
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 6067 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
