glrret's avatar
glrret
Will the netgear EAX80 work with Nighthawk AX6 6-Stream AX5400
I have been using the AX5400 for a few years now but I need to increase my coverage, will the EAX80 work seamlessly? Additionally I run Netgear Armor and is the EAX80 compatible with Armor?
1 Reply
  • It took a little digging, but I think I found the answer to my question on my own.  Thank you for the feedback  😞
