- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Wired Internet but Wireless internet is Intermittent - I can connect wirelessly to all devices.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Just installed today and the wireless works great. Wired connections are fine when I first turn on the device, but then they lose connectivity. Have to reboot the extender to get them working again.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Wired Internet but Wireless internet is Intermittent - I can connect wirelessly to all devices.
Welcome to the community, @garydidio
How is the extender configured?
Is it in AP or Extender mode?
Make sure that there are no other devices that may interfere with the wireless signal.
You may try to move the extender closer to the main wireless source and see if it's a distance problem or it may be too close.
Also, try to play around with the wireless channel and see if it will help.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Wireless works well - Intermittant wired connectivity
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Wireless works well - Intermittant wired connectivity
Check if the devices are still getting IP addresses.
Change as well the Ethernet cable.
If devices disconnect, do you still have lights on the Ethernet port?
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
