× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Wn2000rpt
gabriele63
Wn2000rpt
Hello! I want to buy this product, but first I want to ask if it's possible to change the name of the network with suffix *_ext, in a different name without suffix, and if it is possible to repeat a signal not protected by inserting a protection... thankyou:)
Message 1 of 2
jmizoguchi
Virtuoso
Re: Wn2000rpt
You can use same SSID on _ext.
Unless you are middle of no where you would not want to be setup as open network
You may want detail on what is the goal you are achieving to give you better choices
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 3048 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
