× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
Wn3000rp issue with binatone DT920w router
Arsh21
Guys I just changed my network to Airtel and got new vdsl binatone DT920W router. The speed is 40 mbps but my netgear wn3000rp extender is not going beyond 10 mbps net speed. I read lot of blogs and articles and looks like the band which netgear is mapping to is 802.11g which does not go beyond 54 mbps range. Earlier I had tp link router with Tata Docomo 16 mbps net connection and at that time my extender used to go to 150 mbps to 300 mbps range and my net speed was 16 mbps on extender also. I need your help to understand if there is any setting which needs to changed in binatone config or an extender?Anyone faced such issue? My binatone is set to use all three bands( 802.11 b +g +n.)
Model: WN3000RPv3|N300 WiFi Range Extender
Message 1 of 3
jvasanth1984
Virtuoso
Re: Wn3000rp issue with binatone DT920w router
Hi @Arsh21,
                    This seems to be an issue with channel in which your new router broadcast it's wireless signal. Try to change the channel and check for improvement in speed. Also, perform firmware upgrade if any for your WN3000RP and check.
Message 2 of 3
Arsh21
Hi Jvasanth,
I did lot of RnD on the channel selection and changes but it didn't work out. Yesterday I tried to change the channel width to specifically use 40 Mhz value. That resolved the issue 🙂
Message 3 of 3
Discussion stats
  • 2 replies
  • 3286 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
