Reply
Wn3000rp
Ianpmar
Follower
Wn3000rp
This extender continuously rejects my wifi password key. My router sees the extender no problem...but when registering any device to the extender with the 5ghz key "incorrect" password is displayed on the device....arrrgggghhh...help anyone please
Model: WN3000RP|Universal WiFi Range Extender
Message 1 of 3
Accepted Solutions
DexterJB
NETGEAR Moderator
Re: Wn3000rp
Hi @Ianpmar,
Welcome to the community!
1. You can try accessing the extender's UI to confirm the wireless password.
2. If the extender shows up as a connected device to the router, you can use the IP address of the extender to access the UI.
3. Are your devices able to connect and go online when connected to the 2.4GHz band of the extender?
4. During setup, did you use the same password for the extender and your main router?
Dexter
Community Team
Message 2 of 3
All Replies
DexterJB
NETGEAR Moderator
Re: Wn3000rp
Hi @Ianpmar,
Dexter
Community Team
Message 2 of 3
DexterJB
NETGEAR Moderator
Re: Wn3000rp
Hi @Ianpmar,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1369 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 6E
