Reply
Wn3000rp
synapseE
Wn3000rp
So, how many of these can cascade?
and where is the changelog for the new firmware?
I'm trying to fix a campground setup of 5 of these things all coming from 1 D-Link router. 2-3 hops away. should it work??
Message 1 of 5
jmizoguchi
Virtuoso
Re: Wn3000rp
extender repeat to others but you will decrease in performance on each extended extender behind another
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Message 2 of 5
synapseE
Re: Wn3000rp
I'm working with 5 of these things. As soon as you point 2 of them at the same repeater, they DIE. old firmware and new firmware.
Tomorrow's solution, use #1 as a bridge to a DLink DD-WRT router with strong signal, and point the other 4 to the router.
Wish these things had some "mesh" firmware. That'd be cool and advanced..
Message 3 of 5
jmizoguchi
Virtuoso
Re: Wn3000rp
openmesh.com. product you might be more interested for mesh
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Message 4 of 5
fluminus
Guide
Re: Wn3000rp
I have 2 wn3000RP and I'm trying to configure a dgnd3700 v2. The first repeats the router's signal and the second signal repeater. I tried several times with dhcp configuration with static IP but from the second repeater can not go on the Internet and the network slows down when they are connected to the second
Help me
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 4089 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
