×  Introducing Nighthawk RS700 WiFi 7 (BE) Router. For more details, please visit Nighthawk Tri-Band WiFi 7 Router.
Reply
X6S AmA – What WiFi chipset snd CPU does it use.
avtella
Prodigy
What chipset for WiFi and CPU does the X6S use.
Message 1 of 2
Re: X6S AmA – What WiFi chipset snd CPU does it use.
hi
see
CPU1: Qualcomm IPQ4019 (717 MHz, 4 cores)
FLA1: ? MiB (Brand? Model?)
RAM1: ? MiB (Brand? Model?)
Expansion IFs: USB 2.0
USB ports: 1
WI1 chip1: Qualcomm IPQ4019
WI1 chip2: Qualcomm IPQ4019
WI1 802dot11 protocols: abgn+ac
WI1 MIMO config: 2x2:2
WI1 antenna connector: none
WI2 chip1: Qualcomm Atheros QCA9984
WI2 802dot11 protocols: an+ac
WI2 MIMO config: 4x4:4
WI2 antenna connector: none
ETH chip1: Brand? Model?
LAN speed: 10/100/1000
LAN ports: 4
pretty much exactly the same as the orbi system
 btw if you google make and model name followed by chipset you will get the wikidevi web site for that model
eg
https://wikidevi.com/wiki/Netgear_EX8000
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 733 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
