Orbi WiFi 7 RBE973
Reply
XAV101 powerline adapter compatibility
spiu
Follower
Dear all good morning,
i currenty have 2 XAV101 adapters which are quite old but still doing their job greatly.
Now i need  an addtional adapter to extend the network coverage but i don't know which device should i buy .
Which current adapter  is compatible with mine ?
grazei
M
Model: XAV101|Powerline AV Ethernet Adapter
Message 1 of 2
Guru
Re: XAV101 powerline adapter compatibility
Those are some old power adapters. (2009)
they do use the Homeplug AV spec and will work with 200/500/1000/1200/2000mbps adapters.
The problem that you have won't be in getting devices to connect to them, it'll be the fact that the newer devices will all operate at the slower speeds of the XAV101's do. Powerline devices run at the slowest devices speeds.
More details can be found here:
https://kb.netgear.com/22165/Adding-a-powerline-adapter-to-an-existing-powerline-network
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 431 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
