× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
a6210
jcwinterroth
Follower
a6210
i bought this to use but when i down loaded the standalone driver installation now it sat not compatable with my acer chrome is there a way i can use it?
Model: A6200|802.11ac Dual Band WiFi USB Adapter
Message 1 of 2
Guru
Re: a6210
you say its for your "acer chrome". Is this a chromebook? If so, that wireless adaper is compatible with  windows but not with chromeOS. the majority of the adapters on the market aren't compatible with chromeOS. this wireless adapter will not work with your device if its ChromeOS
Message 2 of 2
Discussion stats
  • 1 reply
  • 604 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
