Rmaynard
Feb 26, 2018Aspirant
after firmware update on wn2000rptv3 extender Admin is not valid
Tried using the serial number Netgear replies as invalid it has checked and double checked Problem did a firmware upgrade 02/25/2018 firmware succeeded tried to long back in ADMIN invalid user name Done the factory reset 3 times did the new device setup three times same result EACH time
Ok maybe some one can make since of this
Trying to resolve problem decided to use a different User Name
It worked in fact I was able to change user name the login will use from admin
1 Reply
- RmaynardAspirant
