× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
ax1800 not able to connect with modem 2.4ghz
kumarnv
Follower
Hi All,
I bought Ax 1800 wifi extender mesh to connect with my vendor modem.
during the setup, the extender used the same ssid but unable to connect since the modem has only 2.4ghz only.
I installed through desktop and able to create seperate ssid for 2.5 and 5. then i connect with ssid with 5 and mobile app worked fine.
did anybody come across the same situation?
regards
kumar
Message 1 of 2
Re: ax1800 not able to connect with modem 2.4ghz
Two points
  • "Ax 1800"  is not a reliable guide to model number. Many devices come with an AX tag, but it is essentially a label that Netgear, and other brands, attach to hardware to describe wifi speeds.
  • What is this vendor modem?
You have posted your message in the section of this community given over to Apps and Services
You might get more help, and find earlier questions and answers about your hardware, in the appropriate section for your device. That's probably here:
WiFi Range Extenders & Nighthawk Mesh - NETGEAR Communities
Message 2 of 2
Discussion stats
  • 1 reply
  • 501 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
