Reply
can i use 2 or even 3 extenders at the same time
markoliver
Follower
have read the previous solutions but having linked both extenders to the router, as soon as I plug in the 2nd extender, I lose the router link to the 1st extender. I bought 3 extenders but so far can only use 1.
Any help would be gratefully accepted
win 7
Model: EX3700|AC750 WiFi Range Extender Essentials Edition
Message 1 of 2
Guru
Re: can i use 2 or even 3 extenders at the same time
Firmware on your extenders?
How are you trying to hook these up? daisy chain or star configuration?
Daisy chain: Router------extender------extender------extender
Star:   extender------->router<------extender
Are you giving each extender its own unique ssid? That's going to be key to making it work properly.
Another thing to keep in mind, in a daisy chain configuration, the more extenders you add, the higher your latency and the slower your speeds.
Current Setup: CM2000-> SXK30-> GS716v2-> Arris W31 x2-> Pi-hole->
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 539 views
  • 0 kudos
  • 2 in conversation
Announcements
