Reply
can't log into ex6150
UD99
Follower
i reset the router and now i can't log in using http://mywifiext.net./. when i go to that url it ask me to set up a new account. after i enter the information it resets to the same screen to set up a new account.
Model: EX6150|AC1200 WiFi Range Extender
Message 1 of 3
Accepted Solutions
DexterJB
NETGEAR Moderator
Re: can't log into ex6150
Hi @UD99,
Welcome to the community!
You may refer to the setup guide on this link. Also, please make sure that a proper reset is done and that you connect the device to the extenders network.
Dexter
Community Team
Message 2 of 3
All Replies
DexterJB
NETGEAR Moderator
Hi @UD99,
Dexter
Community Team
Message 2 of 3
DexterJB
NETGEAR Moderator
Hi @UD99,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 915 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
