× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
cannot connect, says secured, but then says cannot connect to this network
popek
Follower
Model: EX2700|N300 WiFi Range Extender Essentials Edition
Message 1 of 2
scotconor007
Re: cannot connect, says secured, but then says cannot connect to this network
Are you using a VPN to connect through your router? I faced a similar issue while I was using a free proxy extension which showed my real ip instead of a masked ip address, eventually i had to switch to Ivacy, a secure VPN client to rectify that error and it worked. Infact, they are offering a free 7 day trial this month due to covid-19 to flatten the curve.
Model: A6150|AC1200 Dual Band WiFi USB Mini Adapter
Message 2 of 2
Discussion stats
  • 1 reply
  • 264 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
