× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
changing router settings
flugel_1
Follower
when I go to the router settings I can only access my 2.4 GHz settings not my 5.6 GHz settings. How do I go about doing that. I have tried everything. I am connected wirelessly on my 5.6 side.
Message 1 of 5
WizardJ
Luminary
Re: changing router settings
If you go into Advanced -> Setup -> Wireless Setup, you should be able to see settings for both the 2.4 and 5 GHz networks. Can you only see the 2.4 GHz network in here?
Message 2 of 5
WizardJ
Luminary
Also, what router or access point is it that you have? Could you post a screenshot of the Wireless Setup page for us?
Message 3 of 5
jmizoguchi
Virtuoso
All router models thread should be posted under router section
Also no model number
http://forum1.netgear.com/forumdisplay.php?f=31
Message 4 of 5
Retired_Member
Not applicable
If you cannot see a 5g config under the 2.4 config I'm guessing your router is 2.4 Only. I cannot recall any netgear SOHO routers which have a separate page for each band.
Message 5 of 5
Discussion stats
  • 4 replies
  • 8556 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 7
