Reply
ex2700 - can't connect to wifi
hyz
Follower
Follower
My wifi extender isn't connecting to internet.  Device link LED light isn't coming on.  I saw something about updating the hardware but if it doesn't conncet to wifi, how can I do that?  How can I get it to connect to wifi?
Message 1 of 2
DarrenM
Sr. NETGEAR Moderator
Re: ex2700 - can't connect to wifi
Have you tried to factory reset the unit and then try to set it up in the same room as your router. After setup move it to the location you want it to be.
Darrenm
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 210 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
