- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
ex2700
- Mark as New
- Bookmark
- Subscribe
- Permalink
ex2700
had 2 x extenders for several years, all working fine, got an email to upgraade firmware , downloaded file however I can't login to my extenders and forgotton user name and passwords. Went to the password help page and answered the questions and keep getting told the answers are wrong which they can't be as I only went to one first school and only have one brother, been going round and round in circles, driving me mad, can anybody help please?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: ex2700
If you never setup the questions at the start but have password recovery turned on, it'll do that. Basically, you need to reset the devices and when you redo their setup, setup the questions and answers. Keep in mind it is sensative to spaces and upper/lower case for answers.
To reset them, hold the reset button for 7-10 seconds. It'll set it back to factory.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: ex2700
Hi thanks for your reply, that makes sense. Another couple of questions for you as I'm such a thecnophobe.
Once i've pressed the reset button do I have to reconnect the extender to my router and where can I find the setup to do that.
Also will I then have to reconnect my burglar alarm and ring doorbell to them or will they auto reconnect .
many thanks for your help
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: ex2700
@spottydog wrote:Hi thanks for your reply, that makes sense. Another couple of questions for you as I'm such a thecnophobe.
Yes, you do need to redo your installation after resetting the device.
Your devices "should" auto reconnect if you redo your setup with the same ssid and password you had before. Emphasis on should as occassionally people have to forget a wifi setting on their device and reconnect it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: ex2700
here's your support page with installation instructions, firmware updates, and the manual.
