Discussion stats
  • 6 replies
  • 94 views
  • 0 kudos
  • 2 in conversation
Announcements
Top Contributors
Reply
Highlighted
ex3700 no internet all lights
i have a EX3700 and no i do not have any internet connection coming from it either from my phone or when i am trying to connect an ethernet to it .
i am running macOs high sierra 10.13.6
i have tried to reset for 30+ seconds and nothing still yet.
i am running an ASUS RT-Ac86U.
Model: EX3700|AC750 WiFi Range Extender Essentials Edition
Message 1 of 7
Highlighted
Guru
Re: ex3700 no internet all lights
Did you set it up via wps or via the installation wizard?
I'd factory reset it and try setting it up via the wizard
CAX80->GS716v2->RBR50->RBS50-RBS40V-RBS50Y
Message 2 of 7
Highlighted
Yes after I reset it I did it through the wizard.. still no internet connection
Message 3 of 7
Highlighted
Yes I did it through the wizard and still nothing
Message 4 of 7
Highlighted
Guru
do you have any access control/parental controls/device management turn on within your router?
Message 5 of 7
Highlighted
Yes but they’re all off.. nothing to hold back
Message 6 of 7
Highlighted
Guru
Is it new?
I'd recommend opening a support case through netgear for maybe a bad device.
If not, i'd try downgrading the firmware.
Message 7 of 7
