×  Introducing Nighthawk RS700 WiFi 7 (BE) Router. For more details, please visit Nighthawk Tri-Band WiFi 7 Router.
Reply
ex3700 reset button
vampyre
Follower
ex3700 reset button
hi
apologies if this is not the correct location, since it refers to a range
extender but it seemed most appropriate out of the possibles.
however, i want to factory reset a 2nd hand ex3700.
the manual says, use pen and press in the button on the base of the ex3700.
the glitch is i'm blind, and theres a lot of thigns on the base of the ex3700
that are divits u can stick a pen in but none seem to be factory reset
eg. on the ex2700, the factory reset button, actually presses in the the
other 2 physical buttons on the extender.
could anybody with some experience of this, give me a clue whereabouts on the
base the factory reset button is?
many thanks for any ideas forth coming.
Message 1 of 2
Guru
Re: ex3700 reset button
Its actually on the side of it. The snipped and and re-highlighted the spot on it for better viewing.
Current setup: CM2000-> RBKE963B-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 2 of 2
Discussion stats
  • 1 reply
  • 198 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
