× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
ex6100 extender connect by cable
furyanaor
Hello,
i want to use it as a "hot spot" on my room that spread a wifi signal form my wall ethernet port because the room is too far form my router.
there is a switch between my room and the router, that split the enternet to the room's.
i can use the rj45 port of this device to input an internet connection for spread a wifi in my room?? or i need an other product for this job ?
thanks a lot.
bythe way,
if i just connect it to the power without internet input at all,
i can make a LAN network for a LAN-Party ?
Model: EX6100|AC750 WiFi Range Extender
Message 1 of 4
TheEther
Guru
Re: ex6100 extender connect by cable
Flip the extender/access point switch to access point. Then you can connect it to the Ethernet port in the room.
You don't need Internet, but you do need a router for its DHCP server.
Message 2 of 4
furyanaor
So, this device (ex6100) is can be use as Wifi extender
OR a Wifi access point - for my needs?
i get it right ? what i ask for is just an access point devices
and this product can do the trick for me?
- only in case my router can provide a DHCP server through the switch
for and internet connection of course..
*my swith is a NETGEAR GS308.. the router is modem box of my internet provider.
THANKS A LOT !!
Message 3 of 4
TheEther
Guru
Yes, that's right.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 899 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
