- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
ex6150v2 keeps disconnecting exactly every 30m for 2-3 sec
- Mark as New
- Bookmark
- Subscribe
- Permalink
What I've tried:
1. I've made sure the software is updated
2. I've tried reseting it back to factory settings
It happens even when I'm using an ethernet cord plugged into the extender.
My gut feeling is that it is a setting somewhere in the device (like DHCP) that is set to reset every 30m and not every 24hrs.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: ex6150v2 keeps disconnecting exactly every 30m for 2-3 sec
What firmware do you have?
Did you set it up using wps?
What router is it connected to?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Firmware Version: V1.0.1.94
- Yes done using WPS
- WPA2-PSK[AES] is Security
- Router/Modem is NetGear c3700v2
- Mark as New
- Bookmark
- Subscribe
- Permalink
Have you tried factory resetting the extender and installing it using the installation assistant and not wps?
I'd try that method.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Just did and it still happens. Is there not a setting that might cause this to happen? It is literally every 30m to the second. I've timed it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
open a command prompt on a windows pc.
Then type ipconfig /all
that'll give you some data.
It should show when your lease time was obtained and when it expires.
What does it say there?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I figured it was the DHCP. It's showing as only 1 hr.
This is under the Wireless Lan adapter Wi-Fi
- Mark as New
- Bookmark
- Subscribe
- Permalink
Not sure why its dropping at 30 minutes if the lease is 1 hr.
Have you tried setting up static ip addresses in the router for the extender and device connected?
