× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
ex7000 - brand new. All ethernet port LED green
Actioncop
Follower
Brand new device, the only action I get when I plug it into a power source is 5 led lights lit green signifying they are plugged in, but the ports are empty. Nothing else works, can't see the extender wifi network or connect to my router via wps. Trying to reset it doesnt have any affect either, doesnt respond to my holding the reset button at all.
Any help would be appreciated. Thanks
Model: EX7000|AC1900 WiFi Range Extender
Message 1 of 2
DarrenM
Sr. NETGEAR Moderator
Re: ex7000 - brand new. All ethernet port LED green
Hello actioncop
Can you connect via ethernet? if not you may want to exchange it or contact support.
http://www.netgear.com/support/contact.aspx
DarrenM
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 2329 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
