× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
ex7300v2 bought new router, cannot connect extender
adwhitak
We recently had to buy a new router. My wifi extender is connected to the old router. When trying to set it up with the new router, NETGEAR_EXT cannot be found. It is driving me insane. SOMEONE PLEASE HELP
Message 1 of 8
Guru
Re: ex7300v2 bought new router, cannot connect extender
What router did you buy?
Did you factory reset the ex7300 and then re-do the setup?
You can reset it by pushing and holding reset for 7-15 seconds while its powered.
https://www.netgear.com/support/product/EX7300v2
Message 2 of 8
adwhitak
Yes I have done the factory reset. When I go to the nighthawk app to try and set it up, it wants to connect to neatgear_ext but it cannot be found. I’ve tried looking for advice and can not find it anywhere. I bought a 5G Netgear router last week.
Message 3 of 8
Guru
The ex7300 does have an ethernet port on it. direct connect a pc/laptop to it and set it up. just make sure you shut off the wifi on the desktop/laptop you use to set it up so it doesn't default back to that versus the ethernet cord.
Message 4 of 8
adwhitak
Do I do this when the extender is plugged in or not? I’ve done it both ways and it says “internet not connected” when going to my WiFi exit.net I’m really at a loss.
Message 5 of 8
adwhitak
Does my old router need to be plugged in as well?
Message 6 of 8
Guru
plug the extender in.
let it boot up.
Factory reset it by pushing and holding reset for 7-15 seconds while its powered on.
let it reboot. give it a couple minutes.
Disable the wifi on the pc/laptop.  Connect the pc/laptop to it via ethernet.
the go to mywifiext . net
or try 192.168.1.250
follow setup guide.
Message 7 of 8
adwhitak
I did that. Internet will work with all other sites except mywifiext. This is the message I get “this site cannot be reached. It took too long to respond. Try checking your internet connection”
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 1245 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
