wayneh2's avatar
wayneh2
Follower
Mar 04, 2017
extender do i need 300 or 1200 mbps for brighthouse router to stream movies
Am I better off to buy the 1200 mbps or 300mbps extender for streaming movies from brighthouse router?
... and general internet applications.
thanks
wh
  • Hello wayneh2
    It just depends on your budget and the internet connection speed you have the 300 will work fine if your connection is slower than that.
    DarrenM
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello wayneh2
    DarrenM
