× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
extender's wireless network name
CV
Follower
Follower
After connecting with WPS my extender's SSID is not changing to my existing WiFi network name. I have also tried to connect to it using the default password but it will not allow me to join.Any help would be appreciated.
Message 1 of 2
TheEther
Guru
Re: extender's wireless network name
Depending on model of your extender, it will create a Wi-Fi network name similar to your existing Wi-Fi network but with either _EXT, _2GEXT or _5GEXT added to the end. This new Wi-Fi network should have the same Wi-Fi password as your existing Wi-Fi network.
If you want to change the name of the extender's Wi-Fi network to be the same as your existing Wi-Fi network, you will have to log into the extender. The default username and password to log into the extender is admin and password, respectively.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 2453 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
