- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
factory reset for EX6 120 ONLINE AS WONT WORK VIA PIN IN HOLE
- Mark as New
- Bookmark
- Subscribe
- Permalink
HOW DO I RE SET ONLINE WITH EXTENDER CONNECTED TO LAPTOP?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: factory reset for EX6 120 ONLINE AS WONT WORK VIA PIN IN HOLE
many people just push the reset button. It needs to be pushed and held while the extender is fully powered on. Its usually 7-15 seconds but the lights will change/flash once you've held it long enough.
If this doesn't work, let me know.
PS. the caps lock button is to the left of the "A" key.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
You need to go into more details. You put that your couldn't reset the device. Then you're next response is the wifi password is wrong.
Go into details of what you're doing, what steps you've taken, and exactly the points its failing, devices being used, etc.
Also, there is a troubleshooting, video walk throughs, manuals, and install guides on your support site.
https://www.netgear.com/support/product/EX6120.aspx
