jedaraine's avatar
jedaraine
Follower
Jun 29, 2021
how to do reset the password on a nighthawk X4S extender
I forgot the password to my nighthawk X4S mesh extender (havent used it in a while).
I did a factory reset but it did not remove the wifi systems I had used previously.  Just wanting to set up on a new location.
1 Reply
  • plemans's avatar
    When you reset, did you push and hold reset fo r7-15 seconds while it was powered on?
    Many make a mistake and only click on the button.
