rjrp
Jan 26, 2017Aspirant
iptv with EX7000
Hi!
I have one router provided by my Tv company is a Technicolor TG784n v3.
I want to buy an range extender EX7000 to connect by wire to the router, and then distribute the wifi signal on the first floor and connect one tv box with cable to the router. Will i have problems connecting it to the tv box? I already read that many people has problems with it. Just wanted to know it the range extender will work with IPTV, i already looked in the user manual and i don't see the option for VLAN/IPTV Setup like on the routers.
Thanks.
- DarrenMSr. NETGEAR Moderator
Hello rjrp
This will only be setup as a Access point so all the VLan settings would be handled by the router.
DarrenM
- rjrpAspirant
Thanks DarrenM. I ask that because i found a lot information about the IGMP Snooping and that the switches without that won't handle the iptv connections.
So i can connect my iptv to the netgear EX7000.
