Orbi WiFi 7 RBE973
Reply
kindly suggest us suitable layer 2 access switch wih these tech. spes.
iamgovindsingh4
Follower
Type of Switch                                                 Managed
Technology                                                      Non PoE
Number of 1G Copper Ports                          48
Number of 10G Copper Ports                          0
No. of 1 G SFP Port(Uplink)                             4
No. of 10 G SFP+ Port (Uplink)                        0
Multi-Gigabit Support                                      No
Redundant Power supply ( from day one)    Supported
Message 1 of 2
DaneA
NETGEAR Employee Retired
Re: kindly suggest us suitable layer 2 access switch wih these tech. spes.
@iamgovindsingh4,
Welcome to the community! 🙂
I suggest you the M4300-48X managed switch.  It has 48 100/1000/10GBase-T ports and 4 1000/10-Base-X SFP+ shared ports.  Also, it has a modular bay for an optional second PSU.
For more information about the specifications of the M4300-48X managed switch, kindly check its data sheet here
Furthermore, to know more about the NETGEAR Business Switch models that might fit your network requirements, kindly check the link below:
NETGEAR Switch Selector
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
DaneA
NETGEAR Community Team
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 673 views
  • 0 kudos
  • 2 in conversation
Announcements
