- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
model ex3700 doesn't connect to network or devices
- Mark as New
- Bookmark
- Subscribe
- Permalink
this wifi extender arrived in the mail today. i plug it in and try following the connect with WPS instructions. doesn't work. i press the WPS button on the extender, then on the router, and nothing happens.
but okay, w/e. so i try the connect with web browser option.
launch web browser, switch the wifi network from the main router/modem to the extender.
go to mywifi.net
doesn't work.
go to myWiFI.net auto-correct back down to lowercase, but works.
click the new extender setup.
click that i want it in wifi exteder mode, not node mode.
it finds teh 2.4Ghz but not the 5 Ghz in the same physical device. *note* it is in the same room, 9 feet away.
then it asks for a password. i input the password and it doesn't work. so i input the WPA2 key and it doesn't work.
sometimes it responds with "extender was not able t connect to your existing network" other times it brings up a err0r 404 page not found.
neither thing was changed from factory default. both factory defaults are printed on the router itself, and i've double checked multiple times that there are no typos. also i've reset all of the devices, and cold booted them.
how do it get it to work?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: model ex3700 doesn't connect to network or devices
new problem:
typing 'mywifiext.net' doesn't consistently bring up configuration.
since there aren't any comments, do i take it that the product is bugged?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
thank you for the support, btu that doesn't seem to work for me. i'd upload screenshots to help get better support for peopel with the same problem, but there is no image upload function.
