× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
model ex8000 all lights on front are flashing white and factory reset button does nothing
EKU56
Follower
all lights flashing white and power button flashing orange, also factory reset button does nothing when held down for 7 sec.Had it unplugged overnight did the same thing in the morning. it never reallt was reliable cause it would work great for a few days then the speed would drop or couldn't get conected . what are mt options thanks
Message 1 of 2
Guru
Re: model ex8000 all lights on front are flashing white and factory reset button does nothing
It could be a corrupt firmware issue. many times tftp or nmrpflash can recover them.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
https://github.com/jclehner/nmrpflash
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 491 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
