Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
multiple wifi extenders on one network?
- Mark as New
- Bookmark
- Subscribe
- Permalink
2014-09-16
01:39 PM
2014-09-16
01:39 PM
Have installed one WN1000RP on home network that works fine but wanted to extend coverage to far corner of house. Purchased duplicate extender and when I try to use it the LED shows strong wifi signal until I try to connect a tablet or phone to it - when I try this, signal light goes from green to red.
Is it possible to use two separate extenders on one network?
Thanks for any info
Thanks for any info
Message 1 of 5
- Mark as New
- Bookmark
- Subscribe
- Permalink
2014-09-16
02:39 PM
2014-09-16
02:39 PM
Re: multiple wifi extenders on one network?
Hey gascomp,
I'm pretty sure you can have multiple extenders on one network. I would recommend trying a couple of these options
1.Assign the same SSID name and log in credential to both extenders but use different channels. Hopefully your devices will switch over to the needed channel automatically when moving from location A to location B.
2. Try assign a different name to each extender and a different channel. This way you have two different extender on two different channels and you can isolate one extender if need be.
3. you may want to try disconnection the working extender from the network and connect the other one. Try the one you just got and make sure it works. Lets hope you didn't get a bad extender.
If the problem persist I would contact NETGEAR and ask them.
Message 2 of 5
- Mark as New
- Bookmark
- Subscribe
- Permalink
2014-09-23
10:14 AM
2014-09-23
10:14 AM
Tried each extender separately and each works OK but when you plug in the second one, one of the two will begin indicating no wifi signal. Could not figure out how to put each on a separate channel from the router so will just give it up as a bad idea. Thanks for your suggestion.
Message 3 of 5
- Mark as New
- Bookmark
- Subscribe
- Permalink
2014-09-23
12:20 PM
2014-09-23
12:20 PM
You can NOT put extenders on different channels - the extender has to receive the signal on whatever channel the router/access point is transmitting on.
Message 4 of 5
- Mark as New
- Bookmark
- Subscribe
- Permalink
2014-10-01
03:56 PM
2014-10-01
03:56 PM
gascomp
Sorry, my wording for #2 wasn't clear enough. What I meant to say change the name of each extender and then change the channel on the router not the extender. Thanks fordem for catching that.
Message 5 of 5
Announcements
