- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
my wifi ext dont work
- Mark as New
- Bookmark
- Subscribe
- Permalink
i tried several things to fix it.
1. i used WPS for connecting to the modem, becuz it wasnt working with mywifiext. so i tried to reset
2. factory reset
3. moved wifi channel. i read article that might help.
by the way, Im using at&t fiber, and the modem that they gave me. what do i do? (wifi it self works just fine)
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
The lights on the device, illuminate when you have a pc/laptop/phone/etc connected to either the 2.4ghz or 5ghz.
If you set it up using WPS, it automatically sets up in mesh mode (single ssid function) and devices roam between it and the router as needed. If there isn't a device connected, they won't be on.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
