- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
n300 ex2700 connection problems
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi there,
I have had the ex2700 extender for several months now. To begin with its performance was fairly good. The occasional drop out but not too often and never fore very long. However it has become increasingly unstable.
Regularly, devices will be disconneced and I have to forget the connection then re-connect with reentering the password.
Or, it will disconnet then start connecting then disconnect and go on a loop like this for a while before eventually connecting.
And now, devices can be disconnected and when I reconnect it says authorization failed. Even if I forget the connection then re-enter the password, it still says authorization failed.
Can anyone please help me fix this?
Thanks
Greg
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: n300 ex2700 connection problems
Hi gtrance,
Is your EX2700 running the latest firmware?
If you are experiencing frequent interruptions, please try changing your WiFi channel: http://kb.netgear.com/app/answers/detail/a_id/23783/~/improving-2.4ghz-wireless-performance-by-chang...
Please also try resetting your EX2700 back to factory default: http://kb.netgear.com/app/answers/detail/a_id/25226/~/ex2700-faqs
Let us know how it works for you.
NhanN
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
