× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
need to select extended network each time I need it
fredsil
I configured my extenders using the Setup Genie (the mywifiext website did not work). The network seems to work fine, but I need to select it each time I need it. I thought it was supposed to kick in automatically whenever it was needed when my primary network was selected. How should I be selecting the extended network?
Model: EX3700|AC750 WiFi Range Extender Essentials Edition
Message 1 of 3
Guru
Re: need to select extended network each time I need it
The EX3700 isn't a mesh extender. Meaning it doesn't roam automatically.
There's some programs you can install/buy and put on your phone/tablet/pc that'll all you to roam between access points as needed.
But the EX3700 was a base model dual band extender. If you want the roaming option,you'd need to upgrade.
Current setup: CM2000-> RBKE963B-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 2 of 3
fredsil
Thanks. That was a clear explanation. Much appreciated. -Fred
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 202 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
