- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
netgear ex3700 does not authenticate with t-mobile zyxel DX5401-B1 router
- Mark as New
- Bookmark
- Subscribe
- Permalink
I want to use the EX3700 as an extender to the t-mobile zyxel DX5401-B1 router.
I installed the latest firmware V10096_1.0.62 in the EX3700.
Using the WPS procedure, the connection fails.
Configuring using WEB function (Genie) I can select the router (SSID) and enter the password. After some connection processing I receive the message that the connection can not be made.
Any suggestions.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: netgear ex3700 does not authenticate with t-mobile zyxel DX5401-B1 router
Did you set it up using the push button WPS option?
If so, factory reset the extender and set it up using the installation assistant.
To factory reset, push and hold the reset button for 7-15 seconds while powered on.
Here's a video of how to use the assistant.
https://www.youtube.com/watch?v=yJVklshxBMk
also in AP setup: RAXE500->EAX80
1.4gig download/100mbps upload from Xfinity
We’re members of the public helping out on our own time.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Did you set it up using the push button WPS option? >> Yes I did but the connection failed over and over again
If so, factory reset the extender and set it up using the installation assistant. >> I did that and the authentication works. I assume that the problem is with the WPA... which is not supported by the EX3700.
I returned the Netgear extender and bought a Zyxel model.
Case closed
- Mark as New
- Bookmark
- Subscribe
- Permalink
Fair enough. if you returned it you might mark this solved so others aren't still trying to fix it.
Good luck with your current setup
