× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
netgear nighthawk ex7700 - slows down and how do you get it to use 5 Ghz for the up link?
David9
Two issues.
1. The unit occasionally starts to go slow. Speeds start dropping over time and then after, perhaps a few weeks, it slows to a crawl and needs a reboot.
2. It seems to default to the 2.4 G speeds for the uplink channel. Can I force this to the 5G for better throughput?
Model: EX7700|AC2200 Nighthawk X6 Tri-Band WiFi Mesh Extender
Message 1 of 2
Guru
Re: netgear nighthawk ex7700 - slows down and how do you get it to use 5 Ghz for the up link?
You can.
Factory reset it.
When you're going through the reinstall process using the installation assistant, uncheck the "extend 2.4ghz signal".
It'll still let you use the 2.4ghz band but it won't function as a failover for the 5ghz.
Message 2 of 2
Discussion stats
  • 1 reply
  • 462 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
