× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
netgear wn3000rp not finding 802.1
curtm
This wireless range extender finds the WiFi network I would like it to connect to, but says it has WPA2 security, and only allows for the passphrase to be entered.
When I try to connect to the WiFi directly it says the connection uses 802.1 EAP, which asks for a user name AND password. It won't work with just the password, won't let me input t be user name. Any suggestions?
Message 1 of 7
fordem
Mentor
Re: netgear wn3000rp not finding 802.1
What exactly are you having trouble with - connecting the range extender to your WiFi network? When you speak of trying to connect to the WiFi directly - what are you connecting to and what are you connecting with?
Message 2 of 7
jmizoguchi
Virtuoso
Sounds like network you are connection using authentication and not encryption base .
Where are trying to make this connection? Office?
Message 3 of 7
curtm
If I connect to WiFi with my android phone it works slowly in one room and not at all in another.
When I'm logged into the extender it wants me to connect that to the first WiFi source when I open the browser. It only lets me input a password, not user name which is required when logging in to the WiFi directly.
Message 4 of 7
jmizoguchi
Virtuoso
Andriod phone will support 802.11x but extender will not.
Message 5 of 7
jmizoguchi
Virtuoso
None of WN family extender will support 802.11x..
Message 6 of 7
fordem
Mentor
What are you connecting the extender to? Have you followed the extender setup instructions?
Message 7 of 7
Discussion stats
  • 6 replies
  • 11931 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
