× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
new EX6400 extender
tapgriff
Follower
new EX6400 extender
during setup, new extender doesn't show up in my wifi network options. Client Link LED is not on.
Message 1 of 2
Guru
Re: new EX6400 extender
1. did you set it up via wps? if so its default configuration is running as a mesh network. That means it keeps the same ssid as your router. so it won't "appear" on your network list.
2. the client link device lights up if somethings connected to the extender. Is anything connecting to it?
3. if you didn't set it up via wps, did you set it up using the "onessid" feature? again, that'll keep the ssid the same as the routers
Message 2 of 2
Discussion stats
  • 1 reply
  • 259 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
