× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
new router
bemcomputer
Follower
new router
i bought a new router and want to reset and connect the extender. Not sure what the steps are
Model: EX6100|AC750 Dual Band WiFi Range Extender
Message 1 of 2
Guru
Re: new router
You can factory reset the extender by pushing and holding reset for 7-15 seconds while its powered on. then simply follow the install guide.
https://www.netgear.com/support/product/EX6100
Message 2 of 2
Discussion stats
  • 1 reply
  • 262 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
